🎉Community Raffle - Win $25
Join and Win
Thermal simulation in Flux2D - Execution failed
User: "AndyK"
Altair Community Member
Updated by AndyK
Hi, I am performing a thermal simulation of PMSM using Flux2D but when I start solving the execution fails after a few seconds and the following error appears:
PBCEVL_3 => Failed
PBERES_3 => failed
FL5RE4   => Command not executed correctly
FL5ERS   => failed
FL5ERS_1 => failed
executeAlgo => failed
executeAlgo : Execution failed.
PBCEVL_4 => failed
PBCEVL_3 => FailedFL5RE4   => Command not executed correctly
PBCEVL_4 => failed
Do you have any idea what might be a problem? Thanks.
1 - 3 of 31
    User: "asoualmi"
    Altair Employee
    Updated by asoualmi
    Hi,
    Which Flux version that you use? If you use Flux 2020 there is a bug for the thermal application.
    This bug is fixed in version 2020.01
    can you install version 2020.01
    Best regards.
    User: "AndyK"
    OP
    Updated by AndyK
    I am using Flux2D 12.1
    User: "asoualmi"
    Altair Employee
    Updated by asoualmi
    Hi,
    Try to update your Flux version.
    Best regards.
