Questions about composite beams (Hyperlaminate)
User: "Altair Forum User"
Altair Employee
Updated by Altair Forum User
Hi,
im working with carbon unidirectional tubes and i thinking to use these composites tubes as a beam ( 1D Element), but 1D elements only supports MAT1.
I can use the equivalent matrices of the composite sheel tube (2D) to simulate a 1D Beam? Someone can indicate tutorials or topics that talks about this approach, how can i use the equivalent matrices...?
I'm reading this PDF, but i don't know yet how exactly apply this in Hypermesh. (http://cdn.intechopen.com/pdfs/18866.pdf)
Best regards,
Daniel Andrade
1 - 2 of 21
    Altair Employee
    OP
    Hi,
    I dont think this is supported in current version. Maybe someone from Altair team can check regarding the same.
    Instead why not model the beam with 2D?
    Altair Employee
    OP
    Hi Prakash,
    I can model the beam in 2D, but i was thinking to do a parametric optmization, variating the distance of the beams in a truss. Only size optimization supports this in 1D elements, right?
    If I use 2D elements, i will use a topology optmization to find the stress path and make a equivalent truss with tubes. After that i will make a size optimization to change the tickness and diameters to find the better configuration.
    I think in both ideas the result is gonna be satisfatory, but the second one is more simple.
    Thank you for your attention,
    Daniel Andrade
