🎉Community Raffle - Win $25
Join and Win
How to Export Pivot Table along with Table Data using COM
User: "Al_22614"
Altair Community Member
Updated by Al_22614
Hello All:
I am using Monarch COM automation and need to write an VBA script How to Export Pivot Table along with Table Data.  I have tried both EXPORTTABLE and JETEXPORTTABLE, as below, without success.  The Table is exported, but not the Pivot Table.
Option 1:  EXPFILE = MonarchObj.EXPORTTABLE (ExportFolder & ARFILE)
Option 2:  EXPFILE = MonarchObj.JEXPORTTable(ExportFolder & ARFILE, ARTBBL, 0)
Any help will be much appeciated.
Thanks,
Al Rice
1 - 2 of 21
    User: "Mo Abdolrahim"
    Altair Employee
    Accepted Answer
    Updated by Mo Abdolrahim
    Hi Al,
    To export a Monarch Classic table to an Excel file with pivot, perform the following steps:
    Create an export in Monarch Classic,
    Save the model and the project file,
    you can run the project in the com object per following scripts:
    Make sure you add Monarch.exe to the Visual Studio project reference
    Dim MonarchObj As New Datawatch.Desktop.Automation.MonarchAutomationObject
    dim ok as boolean = MonarchObj.SetReportFile("c:\temp\Classic.prn", strPassword, bAppend)
    dim b1 as booleana = MonarchObj.SetModelFile("c:\temp\Lesson9.dmod")
    dim b2 as Boolean = MonarchObj.SetProjectFile("c:\temp\pivot.dprj")
    MonarchObj.RunAllExports()
    I tried the above script and the export contained two tabs, for was the table export and another one was the pivot.
    Regards
    Mo
    Mahmoud Abdolrahim
    Senior Implementation & Integration Engineer
    Altair Engineering
    Original Message:
    Sent: 06-07-2020 05:44 PM
    Subject: How to Export Pivot Table along with Table Data using COM
    Hello All:
    Thanks,
    Al Rice
    User: "Al_22614"
    OP
    Updated by Al_22614
    Hi Al,
    Regards
    Mo
    Mahmoud Abdolrahim
    Altair Engineering
    Original Message:
    Hello All:
    Thanks,
    Al Rice
    Thanks Mo
    Your respond resolves my issue. Thanks again
    Al Rice
    Original Message:
    Sent: 06-08-2020 10:07 AM
    Hi Al,
    Regards
    Mo
    Mahmoud Abdolrahim
    Altair Engineering
    Original Message:
    Hello All:
    Thanks,
    Al Rice
