Model checker Run
User: "Tamilvanan"
Altair Community Member
Updated by Tamilvanan
How to run model checker in scripts to find untied nodes in a tied contact?                                  <?xml version="1.0" encoding="UTF-8"?>image.thumb.png.964bfba03b0c5f6c171d14bd41592e8a.png
1 - 5 of 51
    User: "tinh"
    Updated by tinh
    Can this model checker do that?
    I think we need lsdyna solver to check unconstrained nodes in tied contact (like spotweld)
    User: "Tamilvanan"
    OP
    In Lsdyna profile, we can run 'Untied node check' available under warning section in Model checker. I need to run this particular check in Script itself.
    User: "tinh"
    Updated by tinh
    Did you explore the configuration file?
    Is there some relevant codes inside?
    User: "Tamilvanan"
    OP
    I found the solution. Script is already available in HM itself to open the model checker and run the 'Un-Tied nodes in Contact Tied' check.
    User: "BG913"
    Updated by BG913
    does it work for contact spotweld in dyna properly ?
