🎉Community Raffle - Win $25
Join and Win
HYPERWORKS 2022 ( Student Edition) OptiStruct Mesh Failure
User: "MROWL"
Altair Community Member
Updated by MROWL
Issue :  Mesh Failure on imported  .x_t file from  OnShape . Do not know reason why ?  see attached
Simple beam-Trial performed just to mesh one face prior to meshing an entire assembly ; ;Beam appears to have surface and solid properties Reviewed all tutorials still have issue- any assistance appreciated
Mentor on a FRC team ( retired engr) and some what familar with CAD/CAE
I can send the file if that would help
1 - 3 of 31
    User: "Jason_Craanen"
    Altair Employee
    Updated by Jason_Craanen
    Please keep in mind parasolid files are in meters. Make sure you are using an appropriate mesh size for that part size or scale the part itself
    User: "MROWL"
    OP
    Updated by MROWL
    Thanks for the reply  next issue
    Able to mesh and add constraints and loads ( trial and error method )see attached   A fem file is generated ; If' stress , displacements and contours resulted ;  I can find no report out  visual (graphic)or tabular indication  (using the ribbon task )of any results  like I can in Inspire
    I'm doing sometime wrong or for Hyperworks student edition is that a limitation
    I'm lost
    Where \ how can I get  CAE readout on the model   Sorry I know the model is not pretty  just using it as a test model ( Cad -On shape )
    Altair Employee
    I'm lost
    Are you looking for how to contour/query results?
    You can use Hyperview or HMPOST (Post ribbon directly in Hypermesh)
    https://help.altair.com/hwdesktop/hwx/topics/chapter_heads/post_processing_results_data_hm_r.htm
    You may want to take a look at some intro trainings
    https://learn.altair.com/local/altair_learning_plan/
