I've a model made from importing a DXF file and after a fair bit of work I've nearly got it ready to solve, apart from the error below.
External arc axes and the rotation axis
of the mechanical set ROTOR are different.
The mechanical set rotation is impossible
Concerned line(s) : 85
Line 85 is a curved line attached to 2 points that are on a cylindrical axes that are defined as 138.5 and +- 7.5 degrees. The rotor mechanical set is defined on the same axes. The region holding that face/volume is set as air. As far as I can see there is nothing wrong with that line or axes and everything should line up. Anything else I can check?
