hi sir ,
i have some doubt how to give contact between assembled model , which one is best to give surface to surface contact or node to node contact and penetration coefficient .
Hi Chandra Sekhar,
It completely depends on your model.
If an area coming in contact with an area use surface to surface contact, if a point (say a bullet) coming in contact with a surface use node to surface contact.
