I am using hyperform to evaluate the springback compensation of a component. I created the parameters and saved the '.hf file'. Then while running the analysis with the saved .hf file, the command prompt opens. It could not run the simulation. It shows the error 'noh3d -nproc 1' and 'the system cannot find the path specified'. Have attached with the screenshot of the error. Kindly refer to it and help me regarding this.
Thanks in advance.
'noh3d -nproc 1' are solver options, not error
'system cannot find specified path' means the file 1.hf_0000.rad is not found, perhaps
check it again
