I am trying to run a simple optimization on a cylinder. The problem I am facing is that the optimization is failing and I get this error:
The model must contain valid loads or properly supported so that it can't translate or rotate in any direction
I am attaching some pictures of the model and the settings I am using
Hope you can give me some feedback
Thanks
