What is the best way to compute the superposed coverage from multiple transmitters?
The superposition of the individual coverage results can be done in a network planning project by RunNet based on the corresponding air interface (wireless standard definition file *.wst).
Without network planning module the coverage of individual Tx antennas/leaky feeder cables can be superposed in ProMan by using the following steps:
First load one of the results (preferably *.fpp file) in ProMan via File => Open Result and then superpose the next result via Edit => Combine Data => Max Value (can be done for further results in the same way).
In continuation to the procedure explained above, The Edit window provides multiple options to superimpose the heat maps. for example, heat maps can be added, subtracted, multiplied and combined too with max value, min value and mean value as options within combine dialog.
