Hello everyone,
I am new to Hypermesh and have a question regarding the ZOFFS option.
Also, as an understanding check, can you verify that I understand the hierarchy correctly:
Understanding Check: The hierarchy is as follows
- Component, Property, Material, System, etc.
- Properties must have a Material assigned (to supply to the component)
- Properties must have an Element Type assigned (to supply to the component)
Correct?
Question: I cannot see the ZOFFs option in the Properties Card Edit. I have selected elements and assigned them their element types (CQUAD4 fo example). But when I go to add a ZOFF in the Property Card Edit window, the option does not show. From what I have read online, it seems it should show on the property Card Edit.
It does however show if go to Element Card Edit, select elements, click 'edit'.
Other info: I am using PSHELLS, assigned to the Property. I am in the Nastran profile.
I want to make sure that I am setting everything up correctly.
Thank you for your help!
