Hi everyone,
I have an enclosed volume thanks to 2D triangular meshing elements.
I would like to extract a surface from this meshing but keep those triangles pattern (e.g. each small surface has to be exactly a 2d triangular element of hte previous meshing).
Usually I use the menu 'Geom' -> 'Surfaces' but the result is not what I expect.
Could you give me an advice ?
Thank you in advance,
