hello community
I want to extract the '.hf' file from the '.rad' file. how can I do it ?
I found this files (attached ) in a post on the forum in this post (Composite Forming Simulation (double action, multilayered) ...) and I'm working on the same problem.
You can try importing the *_0000.rad' using the import solver deck>RADIOSS (block) option and then savie it as a HF file.
thank you M.StuDes it works
