I am trying to simulate WiFi signal propagation inside a stitched surface using RL-GO but am receiving the following vague errors:
    (Error 17179: The mesher encountered a problem.
    Error 16561: Mesher aborted - General error.
    Error 17580: The mesher aborted abnormally while meshing PlaneShell.)
    when I try to mesh the structure. 'PlaneShell' is the only component giving the error at this point and is a stitched composite of several surfaces imported from SolidWorks. Interestingly the model will mesh if I scale it down to 0.2 size (the the user-defined variable 'scale') but not if it is unscaled (i.e., setting 'scale' to 1). Additionally, I recently updated from FEKO 7.0 to FEKO 14.0. In FEKO 7.0, I had no issues meshing scaled or unscaled models. I've attached the model.
    Would anyone have suggestions for eliminating this error? I must use RL-GO. Also, does Altair keep a listing of FEKO errors with explanations anywhere? Such a list would make the software far more user-friendly and would eliminate a lot of searching through and waiting for answers from forums.
