are there somewhere detailled informations about how to set material orientation for solid composites?
I want to model a cfrp structure which consists of winded cfrp fibers oriented to the load paths.
It is not possible to simplify the problem with shell elements. It is also not possible to create the solid composite by offsetting the shell composite.
The solid mesh I want to use is created by different cross section shell meshs and line drag.
Is there a possibility to adjust the material orientation of the solids along a line?
Do somebody have another idea how I can adjust the right orientation?
Thank you!
