Hi everybody In the design below I want to optimize the axial ratio around the frequency 1.5Ghz For the probe position and the corner truncation Thanks in advance
Hi gheit
FEKO include the tool OPTFEKO that can be used to optimize parametric geometries such as yours.
Example A06 of the FEKO Examples Guide (ExampleGuide.pdf located in the doc folder of your FEKO installation) gives a good introduction to using OPTFEKO. Also note that the Example Guide models can be found under \examples\ExampleGuide_models\ (again under you FEKO installation folder).
Johan H
