Can anyone tell me how to convert from op2 to res output
Can you please tell me why do you want to change from op2 to res file?
Also you can change from op2 to H3D format using HV trans.
I want to view the results in Hpermesh itself rather than in Hyperview
Go to 'Tools>>Solver'
Then from the options change it to 'hmnasto2'
This should solve your problem.
Thnakyou
Thanks a lot
