2D Meshing between the elements
Juste define a surface within this area and mesh it by keeping the same density. Do equivalent the nodes finally.
0 -
Thank you Nguyen-Dai!
But after doing this way, the elements on the new surface are not connected to the elements from previous surface.
0 -
That why I wrote 'Do equivalent the nodes' !!!
0 -
Hello Amar,
You can try using the command Spline( in 2-D) with the options With/Without/Delete surface. However, before you try this, familiarize yourself with the importance of equivalence command as suggested by Q.Nguyen-Dai.
Also, you may need to project the new nodes/elements on the surface, if the surface is not planar.
