Hello what does this error message mean? How do I fix it?
Wrong specification of the medium for a metallic triangle.
Thanks,
Katrina Y. Montfort
Hi @Katrina Y Montfort
Which application are you using?
I presume that you are using FEKO. If that is the case, error may be due to the overlapping of the metal and dielectric regions. Kindly check if you have defined the regions and mesh settings correctly. It would be great if you could share the model so that we can investigate the problem properly.
