I'm working on my thesis and try to simulate a roller on a track, which moves through a curve.
The roller follows the track and the curve, but as soon as I apply a force on top of the plate, the whole
roller 'falls' trough the track, where it stands at the beginning, even with gravity turned off.
Between the rolls and the track I assigned a contact.
The problem is probably the joint between the rolls and the track, because they are defined as translational
(free) - which works without load, but as I mentioned, not with one.
So, what is the best way to get it solved? Goal is to get the reactions in the curve and do a topology optimization on it.
Thanks for support (y)
