Hi all,
I want to run the model for many times, and each time a different boudary condition is applied. Here I attached a zip file for an example. In the example, I want to run the model using two differnt time series.
The first column of the "differentTimeSeries.txt" is the time for each value (e.g., Day 0, Day 1, Day 2,...). Then, at the first run, the 2nd column will be used as the boundary condition; at the second run, it will be the 3rd column. Please see the figure below.
Is there a way to make Embed read different boundary conditions (time series) automatically at each time?
Thanks!
