When I was use the SPCD to constrain the part's temperature.
I want to check about the temperature is correctly or not.
Can we show how we constrain the tem at the part?
You can use card edit to review temperature value.
@Rahul R Thanks to your reply.
But I can't show the value of the temp
You can pick only one load for the review of temperature constraint.
@Rahul R Really thanks for you.
I finally only pick one then it can show.
Thanks for your help!
