Please help me to launch SnRD directory in Hypermesh. I use Hypermesh 14 and i cannot find SnRD directory among my tabs. Is there some kind of plugin or patch that i need to install/run to use this module of Hyperworks?
Thanks,
Suganya
Hi Suganya,
You need to download package solution software for running SNRD director from Altair Connect and the same has to be enabled in your license.
I recommend you to contact the Altair local support team for more information on the same.
Thanks a ton. It worked
