How to export node id based on LoadCollector in .txt file?
Thank you
Iron_Man59
You can directly get these node ids from the deck file.
As an example, for a RADIOSS file, open the _0000.rad file in Textpad/Notepad and find the load applied where we can see the node ids.
Hi @George P Johnson,
Great...
I can modify the .fem file to modify the constraint directly....
Thank you very much...
