SPWM Controller (3-Phase)
User: "Altair Forum User"
Updated by Altair Forum User
Dear Sirs,
I'm again writing to you for some guidance on this matter.
According to the doc file Digital Power150UG, in chapter 3; there is a controller that I want to utilize directly in my 28377S (specifically Digital Power/ Simulation/ Controllers/ VCM-SPWM 3-phase ).
After I lasso the block and tried to perform Code Gen I get the following: Code generation disabled for compound SPWM (3-phase).
I assume this happens due to I'm in the Simulation section, but the rest of the sections don't have that block (and I don't need the SPWM realization - 3-phase...under Examples/Codegen/PWM).
There are particular steps to utilize and implement this block that I'm not aware?
Or how can I enable the code generation for this compound?
Thank you for your time.
1 - 2 of 21
    OP
    Hello Jake,
    If you would like to generate code please use the ePWM block located in Embedded/Delfino/PWM instead of SPWM block.
    OP
    Hello!
    Thank you for your answer.
    I solved the issue after a long night. The problem was that in the look-up table block and the modulator block both had the Execute interrupt enabled (even with different EPWMs). Just removed one and all worked fine.
    Thank you
