Capture Screenshot in HyperMesh
Altair Forum User
Altair Forum User
Complete newbie here.
I am trying to highlight a few elements and capture screenshot in HyperMesh.
This is the code I have put together by referring to command.cmf file:
*unmaskall()
*createmark(systems,1) 'all'
*maskentitymark(systems,1,0)
*createmark(elements,1) 101 102 103 104
*maskentitymark(elements,1,0)
*maskreverse(elements)
*numbersmark(elements,1,1)
*window(0,0,0,0,0)
after 500
*jpegfilenamed 'Capture.jpg'
Everything works as expected except for the last command to save screenshot. Interestingly, if I give this last command separately in the command window, it works fine.
Any ideas?
Thanks,
Ayush
  • Pandurang
    Pandurang Altair Community Member
    edited August 2018
    try this:
  • Altair Forum User
    Altair Forum User
    edited August 2018
    Still doesn't work.
    I tried hm_windowtofile as well. It has the same issue. Works from command window, but doesn't work as part of the script.
    I am using HM11, if that's relevant.
  • Pandurang
    edited August 2018
    What is error msg ?
  • vipin_22401
    vipin_22401 Altair Community Member
    edited August 2018
    *unmaskall()
    *window(0,0,0,0,0)
    after 500
    Any ideas?
    Thanks,
    Ayush
    Hi @Ayush01
    are you directly writing this code inside userpage file?
    if so change the line to
    *jpegfilenamed(Capture.jpg)
  • QuyNguyenDai
    QuyNguyenDai Altair Community Member
    edited August 2018
    Hi @Ayush01
    @vipin: Noooooooooo, it's WRONG!
    @Ayush01: Try fullpath for JPG file, something like 'C:/Temp/capture.jpg' instead of 'capture.jpg'. It works for my script.
  • vipin_22401
    edited August 2018
    @Q.Nguyen-Dai yes it works for .tcl file, but i am not sure in what format he has written.
    if it is .mac file we have to write it inside brackets ().
  • Altair Forum User
    Altair Forum User
    edited August 2018
    I was saving it in a .cmf file.
    I got it working now with the following code, and tcl format:
    *unmaskall
    *createmark systems 1 'all'
    *maskentitymark systems 1 0
    *createmark elements 1 101 102 103 104
    *maskentitymark elements 1 0
    *maskreverse elements
    *numbersmark elements 1 1
    *window 0 0 0 0 0
    *jpegfilenamed D:/Capture.jpg
    Thank you for suggestions.
  • QuyNguyenDai
    edited August 2018
    In your script, you could :
    • Detect the current folder where's found your HM model and save your picture into this folder.
    • Make automatical increment number into picture file name, so you have 'Capture_001.jpg', 'Capture_002.jpg', 'Capture_003.jpg',....etc
