After reading the Getting Started and User Manual there are a number of Antenna Far Field parameters that I cannot find how to calculate:
   	- Front/Back and/or Front/Rear as a function of frequency
   	- Beamwidth to -3dB levels
   	- Main Lobe/Side Lobe ratio
   	- Antenna Temperature (T) and G/T as a function of frequency
   	I could get some of these manually from a Far Field diagram, but a numerical output from the program would be more practical.
   	Would be most grateful if someone can help.
