When Creating a ID Rod element geometry in Hyper mesh as in the AOC Tutorial 2017, there is a problem with the geometry creation. The nodes are not joining with the line there is a gap between these two nodes and the line, so that cant able to achieve the rod shape.. Moreover same error happen when i tried with 1D bar and rigid element. So cant able to proceed further. I am sure that i follow the tutorial correctly and no any mistakes found in between..so inorder to process further the problem has to get solved.. But same time its shows connection also, but cant able to visualize as rod element..
