I want to create a solid mesh between two meshed surfaces, which will be shared surfaces to the solids they 'belonged to' initially
What I did so far:
0. Working in ABAQUS profile.
1. Automesh (Trias, elm size = 1.5) surfaces of interest
2. With Solid Map, I tried to make a solid mesh starting from the bottom surface, towards the upper surface, along a straight line (curve should also work, but I kept it simple for now).
Problem:
Bottom surface mesh is satisfactory.
Upper surface mesh is 'double'/ not a shared surface and does not follow surface edge.
Using the 'elm to match' option does not work, since this requires same amount of elms on both surfaces, which is not the case.
Thanks in advance!
