Submitted by Joe on Thu, 10/17/2013 - 22:31
For my Master Thesis I will build an Operator for a virtual Plant. So, my problem is to get the readings of several devices. They are stored in a MySql database. The other Problem is to write the used changed Readings to the Database. I am very Thankful if you can Help me build the Blocks, to connect to the different addresses of the Devices.
Friendly Greetings
René
