Can anyone tell me how to set forces inside a hole in one radial direction without getting the answer: 'Please check the forces to be realistic' after calculating my model through? Thank you in Advance
Currently radial load distribution is not available in Inspire.You can apply bearing load and traction load.We will let you know once this feature is available with Inspire.
