I am now trying to import shapefile to a WallMan in order to build a 3D model for propagation computations. During the import i get an error
I can't figure out what exactly the programm doesn't want to except, because when I use another files, which have the same structure it works... Can please someone explain to me what the shapefile should contain in order to be succesfully import to WallMan?
The shapefiles I also add for you:
- the first one (file1) is the actual file I have and need to use (contains more information)
- the second one (file2) is the one I have downloaded from the internet, looks simpler and still does not work well
- the third (file3) was again downloaded from the internet but for some strange reason sucessfully imported by WallMan
Best Regards,
Yaroslav
