In my sense, probably not right or only limited for some cases, mappable in one direction means we can start from one end and drag it along a line until the other end where has a similar shape and this process completes a volume. So I understand why we call a cube is 3 direction mappable( see attached), but for the other one with a splitting corner, I cannot see which end to start and which line it should goes. For the second picture, I understand what is going on for the left figure, but don't know why it is split in the other way(right one). Hope someone can give me an answer. Thanks in advance.
