How to use the hwISession?
Because in the command window if I try hwi GetSessionHandle sess, it gives the following error message
invalid command name 'hwi'.
Do I need any package for calling hwISession?
Sorry guys I was trying the API with HM and not with HW.
Its working fine.
How to get the last error message from the HM batch. For example, if the import file name is invalid, how to get the error message in the hmbatch?
continue this discussion on the other topic you have created for hmbatch error
