Hello!
I have the following question:
Is it possible to set or change the initial temperature of the dummy block (ram stem) in Inspire Extrude, or is the heat transfer to the dummy block neglected?
Many thanks for your answers!
Hello @Konstrukteur ,
This feature is available in the solver and not yet exposed in the interface. If you want to, then you can do it two ways,
Define data packet in GRF file - you can do uniform temperature or non-uniform temperature from external TCL file. You can also initialize temperature from previous simulation ( only requirement is mesh should be same)
