Hi Guys,
i created hex ( solid) using the solid Map. But those elements seem to be Hex8 ( 8 nodes). But i need the Hex20 (20 nodes). HOw do i do this. Config edit >>swtich does not seem to work.
Thanks
Ray
3D => order change => change to 2nd => select elems => change order
Dear Ray,
Rregards,
M Ganesh
