How can i mesh an entire assembly with all the joints that are present in the assembly .
Also please help me out with how can i input those joints in hypermesh.
You can refer Hypermesh Online tutorials.Please see attached screenshot.
sir ,
Thankyou for your reply , but my assembly concists of revolute joints , spherical joints and dampers so in that case how can i connect them .
For eg, lets take a heim joint so i can provide dof to the inner ball but how to connect that inner ball to the main body of heim joint i.e the ball to the bolt part?
please if you can help Rahul R
what solver & what type of analysis you are running at your end?It would help us to understand your problem.
