Hi all,
Is there any way to apply a pressure to a surface as a total magnitude across the surface? The only way I'm finding how to do it right now is by counting the mesh elements and dividing the pressure by the number of elements because the pressure card applies the magnitude to each element instead of the surface as a whole. Wondering how to apply it to the total surface because often the mesh elements are not consistent areas which applies different pressures to different elements.
Thanks for the responses,
Alex
