Altair RISE
Nominate Yourself Now!
Optimization Zero Density
User: "Altair Forum User"
Updated by Altair Forum User
I'm trying to perform a topology optimisation where the constraint is a certain value of stress and the objective is minimise the volume. The optimization just ends up setting the density of all elements to zero (which is a very good way to eliminate stress by the way). Is there any way I can get around this problem so that a sensible value is given for the element densities?
1 - 1 of 11
    OP
    Hi Hypernoob,
    Please read the OptiStrruct FAQs where it is said that 'It is not recommended to use the global stress constraint along with a mass/volume constraint. The constrained mass/volume may not allow the stress constraint to be satisfied.'
    Try the following:
    1) Run only analysis and check if you see any stress/displacement at all. If there is no load going to the structure you will see a similar error.
    If the structure is taking load and still you get the error:
    2) Try with a different constraint like displacement instead of stress and check whether you have an expected result.
