Hello all,
I want to purchase a good system for Hypermesh. What kind of configurations should i take. it should be good enough to handle heavy assemblies. can any one tell please?
Sandeep
PFA hardware recommendation xps file from Hyperworks Indroduction.
what format is this? unable to see sir
PFA same in pdf format.
i gone through system config. actually i am much confuse of technical terms regarding sys cofig you given.....
can you suggest mid level & high level config roughly.
thanks in advance..
The most important is graphic card (GPU). I use Quadro 2000M on my laptop.
The rest, you can get whatever you can.
Thanks Q.Nguyen-Dai
it will handle heavy models? up to 1gb size of file.
A (very) good workstation: CPU Intel core i7 > 3.2 GHz, >=4 core, >= 128 Go RAM, GPU Quadro 4Go
Thanks you all...
