Can someone explain me this error?
Hello Mayank Das,
It Seems the matrix block (Signal based) is getting a data from the modelica block (physical based). Data to the matrix expressions chunks. This cause the interruption to the block.
To avoid the error, convert the physical based data to signal based data.
Requesting you to share the model for reference.
Thank you
Priyanka N
