Hi everyone,I want to change the initial run matrix of optimization but I can not access it (as picture).How can I fix this problem ?Thank for spending your time
Hi Khanh Tran Vu,
The number of lines from the initial run matrix of optimization is that of the population size of the Multi-Objective Genetic Algorithm method, it is automatically generated by the optimization method, and at the moment it can not be manually edited.
Best regards,
Alexandru
