Hi all,
I'm working on a project right now and trying to figure out how to see all the notes saved on the Rhino model in Hypermesh. I've tried using the hm_metadata command but it only returns the notes applied to the whole model. Is there any other metadata command or an option I can add to hm_metadata to see the attributes given to individual solids/surfaces/points? Are these attributes even carried over in the IGES file?
Thank you in advance,
Alex
