Is there any way to get the node between two nodes of a element by tcl command
Have a look at following commands:
Have a look at following commands: *createnodesbetweennodes *createnodesbetweennodelist
Thanks.
but this will create nodes between ....
I need to mark the middle node in a second order element.
for that I asked for that command
I have read a function that manipulate midside node, but I can't remember where it is.
anyway, try:
set Config [hm_getentityvalue elems $Elemid config 0]
switch -- $Config {
106 {
#tria6 elem
foreach Node {node4.id node5.id node6.id} {
lappend MidSideNodes [hm_getentityvalue elems $Elemid $Node 0]
