is there a way to take the loads(forces) that are applied on nodes on mesh and map them on the points that are defined in the same location as the nodes?
Thanks!
Could you explain your requirement in detail?
There are some option in which if you apply load on geometry then it will get map to mesh.Ultimate aim of FEA analysis is to apply load on mesh.
Regards
Rahul R
