I'm trying to learn FEKO after having learned and used Momentum (Keysight ADS) and AXIEM (NI-AWR Microwave Office) for the last 10 years. I'm looking for a lot of dialogues that I'm used to finding in the other software, and I'm not sure where certain things are located in FEKO. I've attached a project that was derived from one of the examples (Microstrip_Filter_FEM) though I also recreated it from scratch and obtain the same results. The result should be very close to a length of 50 ohm line of some length. The S21 result I get from the simulation is in the right ball-park, but S11 is way off.
The relevant project details are:
epsilon_r = 2.33
tand = 0
trace width = 4.6 mm
trace length = 18.4 mm
substrate height = 1.57 mm
perfect electric conductor
I suspect I have not specified something correctly and I think it might have to do with how the regions are defined (or lack thereof). It should be a thin copper strip with above dimensions (0 thickness), over infinite ground plane.
Thank you in advance.
