Hello everybody and I send this question with the hope that someone can help to the main idea o how i can write a script to do the connection between two sheels searching the node more close in the normal vector with 1D rigids.
Thank you in advance.
Hi Juan
your question is not so clearly to me. please describe it more detailly
if you have nodes on sheel1 and you want to find a corresponding node on sheel2 to connect (by 1d rigid)
you can use hm_getclosestnode (please check usage of this in hm help)
