Hi I'm coding new block for my cie and i was wondering if there was a way to change the input and output connectors names depending on the choice made in the dialog box.
Could you please elaborate more on your query??
What application you are trying to use Embed??
Could you please provide your name and contact details ??
Girish
Just to be very precise and provide an answer.
One could in the event function of blockset in Embed look for event ' WM_VSM_CONNECTOR_NAME' and return the needed name for the label. This is already supported in the DLL wizard.
Hope this helps !
--sreeram
