Hi Venky,
This doesn't help.
Please explain what you had done about the project and what is your end objective...
Hi Venky, This doesn't help. Please explain what you had done about the project and what is your end objective...
We have to find out reflection coefficient,gain, vswr
Plz provide your E mail id sir so that I can forward the details
Hi venky,
What tool are you using, What data you have and what inputs you have?
Without this, it is difficult to help.
Hi venky, What tool are you using, What data you have and what inputs you have? Without this, it is difficult to help.
Sir , I was feko software to simulate this project
Actually I designed everything according to ieee paper but i wasn't getting results
Could you pls provide me your contact number so that I can clearly explain you because our project deadline was 22 march
Add your model and the problem that you are running into and we will take a look at it. If you just include the PDF, it requires us to rebuild everything and that is not feasible.
What does this mean? Did you get an error or did you not get the results that you expected? Or did you not have the resources to solve the model?
sir,
i am attaching the ieee paper and the model i designed .
Actually what we have do is ,
in construct tab you will have 'di water1,2,3,4' they are meant to be changed
that is you have do it for four cases
0000-all diwater that is the inner green color should be deleted
1111-all di water should present
0110
1001
I want gain to be 6db and best reflection coffecient and vswr
