How to tranform cordinates with respect to csys?
Hi all,
I have a node , say 659801 and I have coordinates as (138, 150 ,0) and coordinate system id =345
Now, I want the above coordinates with respect to some other coordinate system say, 400.
I am not able to locate HM-APIs which does this transformation?
Please suggest me a way or API to do this transformation of coordinates..
Regards
Gopal
Hi Tinh,
I was able to do the transformation using the command suggested by you.
First I got global x, y z using below commands
set ngx [hm_getentityvalue nodes $node globalx 0]
set ngy [hm_getentityvalue nodes $node globaly 0]
set ngz [hm_getentityvalue nodes $node globalz 0]
Then used the below command for getting coordinate with respect to local system id of need.
set xnode [hm_xpointlocal $n_systemId $ngx $ngy $ngz]
set znode [hm_zpointlocal $n_systemId $ngx $ngy $ngz]
It is working perfectly..
Thanks for your valuable suggestion.It saved a lot of time for me.
Regards
Gopal
try hm_xpointlocal system_id x y z
x y z are global coord, and system_id is a local system
above function will return coordinate x in the local system
